Zum Hauptinhalt wechseln
Black and Decker Toast R Oven Knobs Replacement
Was du brauchst
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: Schritt 1, Bild 1 von 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: Schritt 2, Bild 1 von 2 Black and Decker Toast R Oven Knobs Replacement: Schritt 2, Bild 2 von 2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: Schritt 3, Bild 1 von 1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: Schritt 4, Bild 1 von 1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: Schritt 5, Bild 1 von 1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: Schritt 6, Bild 1 von 1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: Schritt 7, Bild 1 von 1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: Schritt 8, Bild 1 von 1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: Schritt 9, Bild 1 von 1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
Abschluss
To reassemble your toaster, follow these directions in reverse.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jonathan
281 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-10, Propen Fall 2012 Mitglied von Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Mitglieder
Ein Kommentar
very interesting post
James Evans - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 36
Insgesamt: 4,836
