Zum Hauptinhalt wechseln
Nokia N9 Battery Replacement
Was du brauchst
  1. Nokia N9 Battery Replacement, remove top parts: Schritt 1, Bild 1 von 3 Nokia N9 Battery Replacement, remove top parts: Schritt 1, Bild 2 von 3 Nokia N9 Battery Replacement, remove top parts: Schritt 1, Bild 3 von 3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. Nokia N9 Battery Replacement, loosen the screen: Schritt 2, Bild 1 von 3 Nokia N9 Battery Replacement, loosen the screen: Schritt 2, Bild 2 von 3 Nokia N9 Battery Replacement, loosen the screen: Schritt 2, Bild 3 von 3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. Nokia N9 Battery Replacement, disconnect screen from phone: Schritt 3, Bild 1 von 3 Nokia N9 Battery Replacement, disconnect screen from phone: Schritt 3, Bild 2 von 3 Nokia N9 Battery Replacement, disconnect screen from phone: Schritt 3, Bild 3 von 3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
  4. Nokia N9 Battery Replacement, remove screws: Schritt 4, Bild 1 von 1
    • Unscrew the marked screws using the T4 torx screwdriver.
  5. Nokia N9 Battery Replacement, remove covering: Schritt 5, Bild 1 von 2 Nokia N9 Battery Replacement, remove covering: Schritt 5, Bild 2 von 2
    • You will see a strip holding the larger battery cover in place at one side.
    • Rotate the strip a quarter turn along the long axis, and lift it out.
    • Use the opening tool to lift the battery cover up and out.
  6. Nokia N9 Battery Replacement, replace the battery: Schritt 6, Bild 1 von 2 Nokia N9 Battery Replacement, replace the battery: Schritt 6, Bild 2 von 2
    • Click open the battery connector from beneath the connector.
    • Lift the battery from the phone and replace it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
knipwim
8.516 Reputation
30 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 2,503
