Zum Hauptinhalt wechseln
BlackMagic ATEM Television Studio Quiet Fan Upgrade
Was du brauchst
Einführungsvideo
  1. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Unscrew the Outer Case: Schritt 1, Bild 1 von 1
    • 2 Screws on each side
    • 6 Screws on top
  2. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Remove Fans: Schritt 2, Bild 1 von 1
    • Remove Both Fans
    • 2 - Screws each
    • 1 - Pull cable each
  3. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Cut Off Connector from both the olds and new fans: Schritt 3, Bild 1 von 1
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Prep Fan Wires and Connector Wires: Schritt 4, Bild 1 von 1
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: Schritt 5, Bild 1 von 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: Schritt 5, Bild 2 von 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: Schritt 5, Bild 3 von 3
    • For Both Fans
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-assemble fans to device with fan label facing out: Schritt 6, Bild 1 von 1
    • Re-assemble fans to device with fan label facing out.
  7. BlackMagic ATEM Television Studio Quiet Fan Upgrade, OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter: Schritt 7, Bild 1 von 1
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  8. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-Assemble Case: Schritt 8, Bild 1 von 1
    • Re-Assemble Case
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Krautle
508 Reputation
2 Anleitungen geschrieben
5 Kommentare
I have an ATEM Production Studio 4K which had the same issue. This guide was helpful to know how to map the exhaust fan wiring. There are 2 12v heat sync fans that have the same color scheme. I just crimped the wires strait across, and everything worked. I’m now able to live edit without the distraction of a loud switch!
Thank you!!
longears - Antwort
I just did the same on my atem m/e production 4k but the side fans (exhaust) are not on. I wonder if there’s a threshold at which they power on? Any recommendation? The heat sink fans work right away.
Beto Gudiño -
Can I have a schematic diagram for this product ?
Jay Makwana - Antwort
Awesome video, thanks! Do you have a similar iFixit kit and video for the ATEM Mini Pro?
Al Rodriguez - Antwort
Great mod! Did this on my TV Studio HD, nearly non hearable now :)
Andi M - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 71
Insgesamt: 7,140
