Zum Hauptinhalt wechseln
Hot Wheels AI Intelligent Race System Wire Replacement
Was du brauchst
  1. Hot Wheels AI Intelligent Race System Wire Replacement, Controller Wires: Schritt 1, Bild 1 von 1
    • Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
  2. Hot Wheels AI Intelligent Race System Wire Replacement: Schritt 2, Bild 1 von 1
    • Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
  3. Hot Wheels AI Intelligent Race System Wire Replacement: Schritt 3, Bild 1 von 1
    • Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
    • Some wires may require soldering which can be done with a soldering iron. The wire marked in red may need to be soldered but can sometimes be reattached.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 326
