Zum Hauptinhalt wechseln
Garmin Fenix 3 GPS Antenna Replacement
Was du brauchst
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: Schritt 1, Bild 1 von 2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: Schritt 4, Bild 1 von 1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: Schritt 5, Bild 1 von 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the antenna, and set it aside.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
8 Kommentare
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Antwort
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Antwort
Hi did you find gps antenna
Abdessamad Faroque - Antwort
Could you please add a link where to buy the antenna?
marco475 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 46
Insgesamt: 5,249
