Zum Hauptinhalt wechseln
Garmin Fenix 3 Display Assembly Replacement
Was du brauchst
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 2 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Set the watch face aside.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Antwort
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 34
Insgesamt: 9,136
