Einleitung
If your hoverboard will not turn on, retain a charge, move, or spin properly, use this guide to help replace your Hover-1 Titan gyroscope/motherboard.
Was du brauchst
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
Unplug the bottom right connector by squeezing it and pulling it away from the board.
Unplug the blue and white wires by squeezing the connector and pulling away from the board.
Unplug the small white connector by squeezing it and pulling away from the board.
Unplug the charging cable connector by squeezing it and pulling it away from the board.
