Zum Hauptinhalt wechseln
ColecoVision Power Switch Replacement
Was du brauchst
  1. ColecoVision Power Switch Replacement, Power Switch: Schritt 1, Bild 1 von 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Power Switch Replacement: Schritt 2, Bild 1 von 2 ColecoVision Power Switch Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Power Switch Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
  4. ColecoVision Power Switch Replacement: Schritt 4, Bild 1 von 2 ColecoVision Power Switch Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
  6. ColecoVision Power Switch Replacement: Schritt 6, Bild 1 von 1
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Bobby
380 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team S1-G2, Rose Fall 2018 Mitglied von UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,664
