Zum Hauptinhalt wechseln
Huawei Ascend XT Screen Replacement
Was du brauchst
  1. Huawei Ascend XT Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Huawei Ascend XT Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Use the 0.8 Sim driver bit to remove the SIM tray by inserting it into the hole on the side of the device.
    • Once the hole is pressed in firm, the SIM tray will pop out. This allows you to grab it and extract it from the device.
  2. Huawei Ascend XT Screen Replacement: Schritt 2, Bild 1 von 2 Huawei Ascend XT Screen Replacement: Schritt 2, Bild 2 von 2
    • Make a thumbs-up and use it to grip the plastic opening tool with the flat end pointing in the direction of your thumb.
    • Place the flat end of the opening tool slightly inside the charging port and place your thumb on the back of the phone.
    • Press into the phone with your thumb while pulling the opening tool back with your fist to begin prying the back off.
  3. Huawei Ascend XT Screen Replacement: Schritt 3, Bild 1 von 2 Huawei Ascend XT Screen Replacement: Schritt 3, Bild 2 von 2
    • Slide the flat end of the spudger along the edge of the device, prying off the back cover.
    • Carefully remove the back cover. This may be difficult due to glue on the inside.
  4. Huawei Ascend XT Screen Replacement: Schritt 4, Bild 1 von 2 Huawei Ascend XT Screen Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips head bit to remove 20 screws.
  5. Huawei Ascend XT Screen Replacement: Schritt 5, Bild 1 von 3 Huawei Ascend XT Screen Replacement: Schritt 5, Bild 2 von 3 Huawei Ascend XT Screen Replacement: Schritt 5, Bild 3 von 3
    • Carefully pull off the speaker assembly.
    • Carefully pull off the antenna assembly.
    • Carefully pull off the top left tab.
    • Carefully remove the back plate assembly.
  6. Huawei Ascend XT Screen Replacement: Schritt 6, Bild 1 von 1
    • Carefully disconnect battery ribbon wire from lower left corner of circuit board.
  7. Huawei Ascend XT Screen Replacement: Schritt 7, Bild 1 von 2 Huawei Ascend XT Screen Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to pry lithium battery away from battery compartment.
    • Insert new battery and connect.
  8. Huawei Ascend XT Screen Replacement: Schritt 8, Bild 1 von 3 Huawei Ascend XT Screen Replacement: Schritt 8, Bild 2 von 3 Huawei Ascend XT Screen Replacement: Schritt 8, Bild 3 von 3
    • Carefully disconnect screen assembly ribbon wire from mother board.
    • Carefully remove the mother board from the screen assembly.
    • Replace screen assembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,422
