Zum Hauptinhalt wechseln
ZTE Tempo Rear Camera Replacement
Was du brauchst
  1. ZTE Tempo Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 2 ZTE Tempo Rear Camera Replacement, Rear Camera: Schritt 1, Bild 2 von 2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Rear Camera Replacement: Schritt 2, Bild 1 von 2 ZTE Tempo Rear Camera Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. ZTE Tempo Rear Camera Replacement: Schritt 3, Bild 1 von 2 ZTE Tempo Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
omar
717 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 143
