Zum Hauptinhalt wechseln
Samsung Galaxy J3 Mission Screen Replacement
Was du brauchst
  1. Samsung Galaxy J3 Mission Screen Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Screen Replacement, Battery: Schritt 2, Bild 1 von 1
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Screen Replacement, Screen: Schritt 3, Bild 1 von 1
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
Abschluss
To install a new screen try the connector before adding any adhesive, then put it back together by following these steps in reverse order.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph Toth
686 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,920
