Zum Hauptinhalt wechseln
ZTE Tempo Front Screen Assembly Replacement
Was du brauchst
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: Schritt 1, Bild 1 von 2 ZTE Tempo Front Screen Assembly Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: Schritt 2, Bild 1 von 3 ZTE Tempo Front Screen Assembly Replacement: Schritt 2, Bild 2 von 3 ZTE Tempo Front Screen Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: Schritt 3, Bild 1 von 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: Schritt 3, Bild 2 von 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: Schritt 5, Bild 1 von 2 ZTE Tempo Front Screen Assembly Replacement: Schritt 5, Bild 2 von 2
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: Schritt 6, Bild 1 von 3 ZTE Tempo Front Screen Assembly Replacement: Schritt 6, Bild 2 von 3 ZTE Tempo Front Screen Assembly Replacement: Schritt 6, Bild 3 von 3
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
omar
717 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 298
