Zum Hauptinhalt wechseln
HP Mini 210-2070NR Hard Drive Replacement
Was du brauchst
  1. HP Mini 210-2070NR Hard Drive Replacement, Battery and Service Access Cover: Schritt 1, Bild 1 von 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Mini 210-2070NR Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Mini 210-2070NR Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Mini 210-2070NR Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Mini 210-2070NR Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 HP Mini 210-2070NR Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Remove the HP product sticker.
    • Be careful not to pull up the black hard drive plastic connector with the sticker. Also, removing this sticker will void your warranty.
  6. HP Mini 210-2070NR Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP Mini 210-2070NR Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Locate the hard drive, where the HP Product sticker used to be.
    • Locate the hard drive cable, connected to the hard drive.
    • Disconnect the hard drive cable by gently pulling upward.
  7. HP Mini 210-2070NR Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Mini 210-2070NR Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Using a #00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place.
  8. HP Mini 210-2070NR Hard Drive Replacement: Schritt 8, Bild 1 von 2 HP Mini 210-2070NR Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Use the Mylar Tab located on the right side of the hard drive to pry up the hard drive.
    • Remove the hard drive.
  9. HP Mini 210-2070NR Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Lay the hard drive down with the underside facing up.
    • Pull and remove the hard drive pin connector from the hard drive.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Alek Linquist
123 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-23, Amido Fall 2012 Mitglied von Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 15
Insgesamt: 2,267
