Einleitung
Use this guide to help disassemble the keyboard panel for any parts needing to be replaced located under the keyboard panel.
Was du brauchst
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
Once screws are removed you may now remove the optical drive.
Remove the hidden 3mm screw in the optical drive port.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
4 weitere Nutzer:innen haben diese Anleitung absolviert.
