Einleitung
If you find yourself needing to replace the motherboard for your HP Beats Special Edition 15-p390nr, this guide will help you do so.
Was du brauchst
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
Once screws are removed you may now remove the optical drive.
Remove the hidden 3mm screw in the optical drive port.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
You may want yo start with reseating your ram or replacing it
