Zum Hauptinhalt wechseln
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
Was du brauchst
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 3, Bild 1 von 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 3, Bild 2 von 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 7, Bild 1 von 1
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: Schritt 8, Bild 1 von 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: Schritt 8, Bild 2 von 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: Schritt 8, Bild 3 von 3
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 9, Bild 1 von 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: Schritt 9, Bild 2 von 2
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Abschluss
Zack Almeida
392 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 150
