Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15ABR Screen Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
  2. Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 2, Bild 1 von 3 Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 2, Bild 2 von 3 Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
  3. Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 3, Bild 1 von 3 Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 3, Bild 2 von 3 Lenovo Ideapad 320-15ABR Screen Replacement: Schritt 3, Bild 3 von 3
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
How to replace hinge for this model
Deepak Singh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 4,518
