Zum Hauptinhalt wechseln
Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement
Was du brauchst
  1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 3, Bild 1 von 2 Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Lastly, using your hands, separate the motherboard from its compartment.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zack Almeida
392 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 171
