Einleitung
This guide is used to help remove the clear door off the popcorn maker. In order to begin to remove the door, be sure that the machine is unplugged from any outlets and the device is lying on its side.
Was du brauchst
Using a Phillips #1 screwdriver, remove the four 12 mm screws on the red door hinge as indicated, from both the front and side.
Fast fertig!
Abschluss
