Zum Hauptinhalt wechseln
2010-2017 Suzuki Swift Engine Air Filter Replacement
Was du brauchst
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: Schritt 1, Bild 1 von 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: Schritt 1, Bild 2 von 3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: Schritt 1, Bild 3 von 3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: Schritt 2, Bild 1 von 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: Schritt 2, Bild 2 von 2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: Schritt 3, Bild 1 von 1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: Schritt 4, Bild 1 von 2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: Schritt 4, Bild 2 von 2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
knipwim
8.527 Reputation
30 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 135
Insgesamt: 6,343
