Einleitung
Use this guide to replace your PSP Go's headphone jack!
Was du brauchst
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
Remove the two Phillips screws holding the bottom plate.
Gently lift the bottom plate away from the device.
Remove the black Phillips screw holding the headphone jack in place.
Use a pair of tweezers and grasp the black plastic portion of the headphone jack cable.
Slowly pull out the cable. If it's hard to pull, wiggle it slightly side-to-side while pulling it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
