Einleitung
In this guide we will be opening up the HP Envy x2 13-j002dx and replacing the battery. This is an easier repair that can be done by just about anyone. The only screw driver required is a Philips #0 and a Philips #00 screw drivers. You will also need a pair of tweezers and a set of opening picks.
Was du brauchst
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
Use an opening pick to remove the plastic cover above the back stand.
Pry the cover off.
Use a Phillips #0 screwdriver to remove the four 4 mm screws.
Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
Carefully pull up on the battery connector from the speaker.
Use a pair of tweezers and remove the taped down wire for the speaker.
Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
