Zum Hauptinhalt wechseln
Asus Chromebook C300SA-DS02 Trackpad Replacement
Was du brauchst
  1. Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: Schritt 5, Bild 1 von 2 Asus Chromebook C300SA-DS02 Trackpad Replacement, Trackpad: Schritt 5, Bild 2 von 2
    • Flip over the keyboard assembly to reveal the trackpad beneath.
  6. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 6, Bild 2 von 2
    • Peel up the two pieces of foil tape holding down the trackpad.
  7. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 7, Bild 1 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 7, Bild 2 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 7, Bild 3 von 3
    • Use a spudger to release the locking bar of the ZIF connector near the center of the trackpad.
    • Slide the cable ribbon from the connector.
  8. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Peel back the ribbon cable, which is adhered to the trackpad.
  9. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 9, Bild 1 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 9, Bild 2 von 3 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 9, Bild 3 von 3
    • Remove the four 2.5mm Phillips #0 screws along the top edge of the trackpad.
  10. Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 10, Bild 1 von 2 Asus Chromebook C300SA-DS02 Trackpad Replacement: Schritt 10, Bild 2 von 2
    • Pry the trackpad from the top edge with a finger or spudger.
    • Lift the trackpad up and away from the keyboard assembly.
Abschluss
Austin Blakely
19.503 Reputation
53 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.767 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 179
