Zum Hauptinhalt wechseln
Lenovo IdeaPad 330S NVMe Drive Replacement
Was du brauchst
  1. Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: Schritt 1, Bild 2 von 2
    • Turn off the device before working on it.
    • Remove the 10 screws as shown in the picture
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S NVMe Drive Replacement, Disconnecting Battery: Schritt 2, Bild 1 von 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S NVMe Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4 screws according this picture
    • Gently pry out the black case.
  4. Lenovo IdeaPad 330S NVMe Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the Screw as shown in picture
    • The drive will lift, remove gently the drive.
    • Install the new drive and screw it to the motherboard
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ilia Tocheny
1.616 Reputation
9 Anleitungen geschrieben
7 Kommentare
Is this machine compatible with both NVMe SSD and SATA SSD on the M2 port? Thank you.
notyourITguy - Antwort
This machine is compatible NVMe and Sata drive.
Ilia Tocheny -
mine came with m2 2242 ssd and is reaching its lifespan, can I replace it with m2 2280?
Kaizoku 62 - Antwort
Yes you can but before you do this… make sure to backup all data before doing the upgrade. When you will install the new ssd make you sure it is Nvme gen 3 and not gen4.
Samsung 980 is recommended ssd for the upgrade…
Ilia Tocheny - Antwort
any reason why I cannot install nvme gen4? its the same price as gen3
isnt it backwards compatible?
Kaizoku 62 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 4,859
