Zum Hauptinhalt wechseln
Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement
Was du brauchst
  1. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the sprocket guard plate: Schritt 1, Bild 1 von 1
    • Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
  2. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 2, Bild 1 von 1
    • Remove the sprocket guard plate.
  3. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain and guide bar: Schritt 3, Bild 1 von 1
    • If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
    • During reassembly, if you are reinstalling the chain and guide bar, follow the manufacturers instructions on proper chain tensioning techniques.
  4. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain brake cover: Schritt 4, Bild 1 von 1
    • Remove the four 12 mm long T27 screws securing the chain brake cover.
  5. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 5, Bild 1 von 1
    • Remove the chain brake cover.
  6. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the tensioner assembly: Schritt 6, Bild 1 von 1
    • Twist the tension screw clockwise until the slide bar stops at the right end.
    • Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
  7. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 7, Bild 1 von 1
    • Use your fingers to pull the assembly out of its recess and remove it.
  8. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 8, Bild 1 von 1
    • If the packing ring did not come out with the assembly, remove it from the recess.
  9. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Assemble the replacement tensioner: Schritt 9, Bild 1 von 1
    • The next three steps show how to prepare the new tensioning assembly for replacement.
    • Lightly lubricate the packing ring and press it into the back of the adjustment screw.
  10. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 10, Bild 1 von 1
    • Slide the adjustment screw into the tensioning assembly such that the gears mesh together.
  11. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 11, Bild 1 von 1
    • Slide the shaped plastic bearing onto the end of the assembly.
    • Lightly lubricate all moving surfaces.
  12. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: Schritt 12, Bild 1 von 1
    • Line up the tensioning assembly with its recess in the chainsaw and push it into the recess.
    • Make sure that the black plastic bearing slides in rounded-edge first.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Arthur Shi
252.687 Reputation
526 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.816 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 2,333
