Zum Hauptinhalt wechseln
Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement
Was du brauchst
  1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 5, Bild 3 von 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 6, Bild 2 von 2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: Schritt 7, Bild 1 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: Schritt 7, Bild 2 von 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
  8. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: Schritt 8, Bild 1 von 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: Schritt 8, Bild 2 von 2
    • Locate the three snap on ribbon cable connectors on the motherboard.
    • Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
  9. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 9, Bild 1 von 1
    • With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
    • Take care when moving the motherboard not to allow any of the ribbon cables to be pulled on.
    • The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
  10. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
    • Take care to not damage the button itself or its connecting ribbon cable when detaching the button.
    • The glue which holds the button in place will remain tacky allowing the button to be replaced without the need for additional glue.
  11. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 11, Bild 1 von 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 11, Bild 2 von 2
    • With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
    • Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
    • The Headphone Jack is held in place with adhesive that will remain tacky after being removed, allowing it to be replace without the need for additional glue.
  12. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 12, Bild 1 von 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
    • The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
    • With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 18-37, Regan Winter 2013 Mitglied von Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Nice Idea Good for beginners. :)
Spy Mike - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 3,044
