Zum Hauptinhalt wechseln
HP Elitebook 8460p Cooling Fan Replacement
Was du brauchst
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: Schritt 5, Bild 1 von 2 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: Schritt 5, Bild 2 von 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: Schritt 6, Bild 1 von 2 HP Elitebook 8460p Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: Schritt 7, Bild 1 von 2 HP Elitebook 8460p Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: Schritt 8, Bild 1 von 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: Schritt 9, Bild 1 von 2 HP Elitebook 8460p Cooling Fan Replacement: Schritt 9, Bild 2 von 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: Schritt 10, Bild 1 von 1
    • Blow compressed air through the vent from the outside and through the heat sink.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 47
Insgesamt: 4,463
