Zum Hauptinhalt wechseln
IKEA KOPPLA Connector (fix)
Was du brauchst
  1. IKEA KOPPLA Connector (fix), break open the adapter: Schritt 1, Bild 1 von 3 IKEA KOPPLA Connector (fix), break open the adapter: Schritt 1, Bild 2 von 3 IKEA KOPPLA Connector (fix), break open the adapter: Schritt 1, Bild 3 von 3
    • open device , using brute force is the only option because it's ultrasonic welded together.
    • use screw driver or squeeze in a vice to crack it open.''
  2. IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): Schritt 2, Bild 1 von 2 IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): Schritt 2, Bild 2 von 2
    • Resolder all the USB connector pins (red box'es), on all 3 USB connectors to be sure they are functional. (on this image the top one is defective)
    • The reason solder points break is the connector support is soldered onto the board on one side only. Not by the arrow. Thereby adding stress directly to the soldered pins.
    • In addition the connector pin (square) near the U2 marking is too short and therefore may not be soldered properly.
    • see 2nd image for example of front support pin is pulled out of solder area.
  3. IKEA KOPPLA Connector (fix), add glue to connectors: Schritt 3, Bild 1 von 2 IKEA KOPPLA Connector (fix), add glue to connectors: Schritt 3, Bild 2 von 2
    • add hot melt glue in these areas on the board and on the side of the connector.
    • Add the cover first to understand where there is room for it in the cover.
    • If connector is not glued, it is likely the charger will stop working again in the near future.
    • Ikea have been notified of this issue.
    • To seal the enclosure , add suitable glue to edge, and press the top/bottom together.
    • Use as vice while holding them together, while the glue hardens.
Abschluss
I understand these adapters are cheap, but they can be repaired as described.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 65
Insgesamt: 2,600
