Einleitung
This guide will involve the removal of various screws, as well as detaching the two gold ribbons connecting the motherboard to the camera.
Was du brauchst
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Remove the second battery cover on the bottom of camera.
Take the silver battery out of the camera.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
Remove the 4mm Phillips #00 screw at the bottom of the black piece.
Detach the black piece that the screws previously held in place.
Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
Once unlocked, slide out the ribbon.
Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
