Zum Hauptinhalt wechseln
Razer Naga Trinity Disassembly
Was du brauchst
  1. Razer Naga Trinity Disassembly, Razer Naga Trinity Disassembly: Schritt 1, Bild 1 von 2 Razer Naga Trinity Disassembly, Razer Naga Trinity Disassembly: Schritt 1, Bild 2 von 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity Disassembly: Schritt 2, Bild 1 von 2 Razer Naga Trinity Disassembly: Schritt 2, Bild 2 von 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity Disassembly: Schritt 3, Bild 1 von 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity Disassembly: Schritt 4, Bild 1 von 2 Razer Naga Trinity Disassembly: Schritt 4, Bild 2 von 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity Disassembly: Schritt 5, Bild 1 von 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity Disassembly: Schritt 6, Bild 1 von 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity Disassembly: Schritt 7, Bild 1 von 2 Razer Naga Trinity Disassembly: Schritt 7, Bild 2 von 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
Abschluss
18 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
I would like to to point out that at step 7, second picture, the 3-pin connector is for the top 2 buttons. the RGB LED is actually in the board and can be seen in step 7 first picture, tiny white square at the bottom, top left where it says K7-D1.
Jaidee Sasaki - Antwort
The cable for the Naga2014 fits admirably and appears to work fully, BUT NOTE: the green and white wires need to be swapped around in the plug at the end that connects inside the mouse.
Chris Gravell - Antwort
How do you open up the side plates so you can clean inside them?
Teach - Antwort
If you feel along the back, you'll notice that it is 'rougher' than the injection-molded plastic; this is a sticker that hides 4 Phillips #1 screws and two more magnets. Peel off the sticker and remove the screws--the plate should then lift right out. I... discovered this the hard way after destructively disassembling a broken 12-button part because the design LOOKS like it just clips on, and I wasn't sure if this was a heat glue situation or something else. Here's the 6-button part fully disassembled. https://i.imgur.com/xK7IPus.jpg
Warmachine (Warmachine) -
How do you remove the board so that you can replace the mouse buttons when they break?
kbenaca654 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 105
Letzte 30 Tage: 457
Insgesamt: 32,187
