Zum Hauptinhalt wechseln
Xbox One S All Digital Edition Power Supply Replacement
Was du brauchst
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: Schritt 1, Bild 1 von 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: Schritt 1, Bild 2 von 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: Schritt 1, Bild 3 von 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: Schritt 2, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: Schritt 3, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement: Schritt 3, Bild 2 von 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: Schritt 4, Bild 1 von 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: Schritt 5, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: Schritt 5, Bild 2 von 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: Schritt 6, Bild 1 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 6, Bild 2 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 6, Bild 3 von 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: Schritt 7, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: Schritt 7, Bild 2 von 2
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the WiFi Card from the metal chassis.
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: Schritt 9, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: Schritt 9, Bild 2 von 2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: Schritt 10, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement: Schritt 10, Bild 2 von 2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: Schritt 11, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: Schritt 11, Bild 2 von 2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: Schritt 12, Bild 1 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 12, Bild 2 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 12, Bild 3 von 3
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: Schritt 13, Bild 1 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 13, Bild 2 von 3 Xbox One S All Digital Edition Power Supply Replacement: Schritt 13, Bild 3 von 3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: Schritt 14, Bild 1 von 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: Schritt 14, Bild 2 von 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: Schritt 14, Bild 3 von 3
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: Schritt 15, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement: Schritt 15, Bild 2 von 2
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: Schritt 16, Bild 1 von 2 Xbox One S All Digital Edition Power Supply Replacement: Schritt 16, Bild 2 von 2
    • Disconnect the six pin connector from the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jules Hajjar
1.531 Reputation
8 Anleitungen geschrieben
Cal Poly, Team S12-G6, Regan Fall 2019 Mitglied von Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Mitglieder
25 Anleitungen geschrieben
3 Kommentare
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - Antwort
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 30
Letzte 30 Tage: 131
Insgesamt: 6,738
