Zum Hauptinhalt wechseln
Logitech MBJ58 Mouse Support Spring Replacement
Was du brauchst
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: Schritt 1, Bild 1 von 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Support Spring Replacement: Schritt 2, Bild 1 von 2 Logitech MBJ58 Mouse Support Spring Replacement: Schritt 2, Bild 2 von 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 1 von 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 2 von 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 3 von 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: Schritt 4, Bild 1 von 2 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: Schritt 4, Bild 2 von 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: Schritt 5, Bild 1 von 2 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: Schritt 5, Bild 2 von 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 5-14, Forte Winter 2013 Mitglied von Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 3,864
