Zum Hauptinhalt wechseln
Logitech MBJ58 Mouse Buttons Replacement
Was du brauchst
  1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: Schritt 1, Bild 1 von 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Buttons Replacement: Schritt 2, Bild 1 von 2 Logitech MBJ58 Mouse Buttons Replacement: Schritt 2, Bild 2 von 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Buttons Replacement, Buttons: Schritt 3, Bild 1 von 2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: Schritt 3, Bild 2 von 2
    • Locate the two tabs that are protruding from the button assembly.
    • Be careful not to break either of the two tabs by squeezing too hard.
    • Pinch the tabs together to free the buttons.
  4. Logitech MBJ58 Mouse Buttons Replacement: Schritt 4, Bild 1 von 2 Logitech MBJ58 Mouse Buttons Replacement: Schritt 4, Bild 2 von 2
    • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
    • Slide the button assembly out from the top cover through the opening.
    • When fully disassembled, the top cover and the button assembly should look like this.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 5-14, Forte Winter 2013 Mitglied von Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 2,901
