Zum Hauptinhalt wechseln
Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement
Was du brauchst
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 2, Bild 3 von 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: Schritt 3, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: Schritt 3, Bild 2 von 2
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 4, Bild 3 von 3
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Microphone: Schritt 6, Bild 1 von 1
    • Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 7, Bild 2 von 2
    • Remove the microphone component from the rest of the computer by detaching the connected wire.
    • The camera component of the laptop is connected to the same wire, so remove this as well.
    • The camera is only held down with adhesives, so there is no need to use any tools.
  8. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 8, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 8, Bild 2 von 2
    • Remove the microphone and camera wire out from around the display screen.
    • Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Carefully remove the adhesive tape and take out the ribbon cable.
  9. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: Schritt 9, Bild 2 von 2
    • Remove the microphone from the laptop.
Abschluss
Ian Sullivan
116 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 631
