Zum Hauptinhalt wechseln
LG VX5300 Keypad Replacement
Was du brauchst
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: Schritt 1, Bild 1 von 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: Schritt 1, Bild 2 von 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: Schritt 1, Bild 3 von 3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: Schritt 4, Bild 1 von 2 LG VX5300 Keypad Replacement, Keypad: Schritt 4, Bild 2 von 2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: Schritt 5, Bild 1 von 2 LG VX5300 Keypad Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: Schritt 6, Bild 1 von 1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: Schritt 7, Bild 1 von 2 LG VX5300 Keypad Replacement: Schritt 7, Bild 2 von 2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: Schritt 8, Bild 1 von 2 LG VX5300 Keypad Replacement: Schritt 8, Bild 2 von 2
    • Insert the battery.
    • Slide the back cover on the phone.
Ziellinie
Ashley
13 Reputation
3 Anleitungen geschrieben
Ohio State, Team 1-1, Buehl Spring 2013 Mitglied von Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 552
