Zum Hauptinhalt wechseln
American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement, Remove the sanding disc: Schritt 1, Bild 1 von 3 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement, Remove the sanding disc: Schritt 1, Bild 2 von 3 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement, Remove the sanding disc: Schritt 1, Bild 3 von 3
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  2. American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 2, Bild 1 von 2 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 2, Bild 2 von 2
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  3. American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 3, Bild 1 von 2 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  4. American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 4, Bild 1 von 3 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 4, Bild 2 von 3 American Sanders EZSand Orbital Sander 07163A 2012 Sanding Disc Assembly Replacement: Schritt 4, Bild 3 von 3
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
Abschluss
Adam O'Camb
195.358 Reputation
416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 18
