Zum Hauptinhalt wechseln
Samsung BlackJack II Front Casing Replacement
Was du brauchst
  1. Samsung BlackJack II Front Casing Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung BlackJack II Front Casing Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung BlackJack II Front Casing Replacement, Battery: Schritt 1, Bild 3 von 3
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Samsung BlackJack II Front Casing Replacement: Schritt 2, Bild 1 von 3 Samsung BlackJack II Front Casing Replacement: Schritt 2, Bild 2 von 3 Samsung BlackJack II Front Casing Replacement: Schritt 2, Bild 3 von 3
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  3. Samsung BlackJack II Front Casing Replacement, Back Casing: Schritt 3, Bild 1 von 2 Samsung BlackJack II Front Casing Replacement, Back Casing: Schritt 3, Bild 2 von 2
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
  4. Samsung BlackJack II Front Casing Replacement: Schritt 4, Bild 1 von 1
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
  5. Samsung BlackJack II Front Casing Replacement: Schritt 5, Bild 1 von 3 Samsung BlackJack II Front Casing Replacement: Schritt 5, Bild 2 von 3 Samsung BlackJack II Front Casing Replacement: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
  6. Samsung BlackJack II Front Casing Replacement, Front Casing: Schritt 6, Bild 1 von 2 Samsung BlackJack II Front Casing Replacement, Front Casing: Schritt 6, Bild 2 von 2
    • Pry apart the plastic tabs along the edges of the phone.
    • Separate the front panel from the main body of the phone using your fingers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Rumsey
8 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-1, Maness Winter 2013 Mitglied von Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 442
