Einleitung
Follow this guide to replace the SSD in your Lenovo YOGA 730-15IKB. The SSD—like its older predecessor, the hard drive—is where files are stored on your computer. If your SSD is getting full, you could upgrade to a higher capacity drive for more storage space.
If your computer powers on and lights up but does not boot into an operating system (like Windows), you may need to replace a failed SSD.
It is always a good idea to make a backup of your data before removing your SSD.
Was du brauchst
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pry up the bottom cover with an opening tool.
Start at the front edge of the cover and make your way along the sides.
Pull the SSD out of the socket at its resting angle.
Do not pull straight upward. Pull towards the side of the laptop.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
