Zum Hauptinhalt wechseln
Lenovo Yoga 910-13IKB SSD Replacement
Was du brauchst
  1. Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 2, Bild 1 von 1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 3, Bild 1 von 1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 4, Bild 1 von 1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga 910-13IKB SSD Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga 910-13IKB SSD Replacement: Schritt 5, Bild 3 von 3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 6, Bild 1 von 3 Lenovo Yoga 910-13IKB SSD Replacement: Schritt 6, Bild 2 von 3 Lenovo Yoga 910-13IKB SSD Replacement: Schritt 6, Bild 3 von 3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB SSD Replacement, SSD: Schritt 7, Bild 1 von 1
    • Remove the 3mm JIS #00 screw holding the storage in place.
  8. Lenovo Yoga 910-13IKB SSD Replacement: Schritt 8, Bild 1 von 2 Lenovo Yoga 910-13IKB SSD Replacement: Schritt 8, Bild 2 von 2
    • Pull up lightly on the drive and gently pull it out of the connector.
Abschluss
Nikhil Nagarajan
97 Reputation
1 Anleitung geschrieben
Cal Poly, Team S1-G5, White Winter 2020 Mitglied von Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 23
Letzte 30 Tage: 112
Insgesamt: 5,638
