Zum Hauptinhalt wechseln
Acer Spin 5 SP513-51-57TP Motherboard Replacement
Was du brauchst
  1. Acer Spin 5 SP513-51-57TP Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 3, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 3, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 4, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 4, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 5, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 5, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Motherboard Replacement, CMOS Battery: Schritt 6, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, CMOS Battery: Schritt 6, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, CMOS Battery: Schritt 6, Bild 3 von 3
    • Grasp the CMOS battery with the tweezers and remove it from the motherboard.
  7. Acer Spin 5 SP513-51-57TP Motherboard Replacement, Solid State Drive: Schritt 7, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Solid State Drive: Schritt 7, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Solid State Drive: Schritt 7, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
  8. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 8, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 8, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Use your hand to pull out the Solid State Drive from the motherboard.
    • You will be pulling the solid state drive out to the left, as it will be connected to the port on the motherboard on its right side. This is opposite the direction that the pictures depict it.
  9. Acer Spin 5 SP513-51-57TP Motherboard Replacement, Cooling Fan: Schritt 9, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Cooling Fan: Schritt 9, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Cooling Fan: Schritt 9, Bild 3 von 3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  10. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 10, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  11. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 11, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 11, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
  12. Acer Spin 5 SP513-51-57TP Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Use the tweezers to disconnect the wiring harness in the bottom right corner of your laptop.
  13. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 13, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 13, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Using the tweezers, flip the white lock tab of the ZIF connector upward.
    • Pull the blue "MB High-Tek" ribbon cable out.
  14. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 14, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Using the tweezers, pull the black CQWP connection wire from its port.
  15. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 15, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Using the tweezers, flip up the black lock tab of the ZIF connector upward.
    • Pull out the MB purple ribbon cable out.
  16. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 16, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 16, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Using the tweezers, remove the black drift cable from its port.
  17. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 17, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Using the tweezers, pull out the orange GND VCC connection wire.
  18. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 18, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 18, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 18, Bild 3 von 3
    • Using the tweezers, flip up the black lock from the connector holding the display cable.
    • Remove the display connection wire from its port.
  19. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 19, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 19, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 19, Bild 3 von 3
    • Using Phillips #1 screwdriver, remove the 4mm screw that secure the WiFi card.
    • Remove WiFi card from its port.
  20. Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 20, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 20, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Motherboard Replacement: Schritt 20, Bild 3 von 3
    • Using Philips #1 screwdriver remove the seven 4mm screws that secure the motherboard to the laptop.
    • Remove the motherboard by lifting it out from the back case.
Abschluss
Hufflepuff Mitglied von Hufflepuff
Repair Café
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I was wondering if the CPU is soldered to the motherboard? Is it possible to remove the CPU and replace it with an upgraded CPU?
Drew Nelson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 1,457
