Zum Hauptinhalt wechseln
InFocus IN3104 Lamp Replacement
Was du brauchst
  1. InFocus IN3104 Lamp Replacement, Top Cover: Schritt 1, Bild 1 von 3 InFocus IN3104 Lamp Replacement, Top Cover: Schritt 1, Bild 2 von 3 InFocus IN3104 Lamp Replacement, Top Cover: Schritt 1, Bild 3 von 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Lamp Replacement: Schritt 2, Bild 1 von 3 InFocus IN3104 Lamp Replacement: Schritt 2, Bild 2 von 3 InFocus IN3104 Lamp Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: Schritt 3, Bild 1 von 2 InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: Schritt 3, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Lamp Replacement: Schritt 4, Bild 1 von 3 InFocus IN3104 Lamp Replacement: Schritt 4, Bild 2 von 3 InFocus IN3104 Lamp Replacement: Schritt 4, Bild 3 von 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Lamp Replacement, Lamp: Schritt 5, Bild 1 von 3 InFocus IN3104 Lamp Replacement, Lamp: Schritt 5, Bild 2 von 3 InFocus IN3104 Lamp Replacement, Lamp: Schritt 5, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws.
    • You may need to use a flexible extender to help remove the screws easily.
  6. InFocus IN3104 Lamp Replacement: Schritt 6, Bild 1 von 3 InFocus IN3104 Lamp Replacement: Schritt 6, Bild 2 von 3 InFocus IN3104 Lamp Replacement: Schritt 6, Bild 3 von 3
    • Remove the lamp power cable situated beside the lamp by pulling it straight out.
    • Remove the lamp by pulling it straight out from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 598
