Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out of the frame and remove it from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S7-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Antwort
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 44
Letzte 30 Tage: 205
Insgesamt: 11,444
