Zum Hauptinhalt wechseln
HP Envy m6-1225dx Optical Drive Replacement
Was du brauchst
  1. HP Envy m6-1225dx Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Optical Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy m6-1225dx Optical Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy m6-1225dx Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery
  4. HP Envy m6-1225dx Optical Drive Replacement: Schritt 4, Bild 1 von 2 HP Envy m6-1225dx Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Optical Drive Replacement: Schritt 5, Bild 1 von 2 HP Envy m6-1225dx Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Optical Drive Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Optical Drive Replacement: Schritt 7, Bild 1 von 2 HP Envy m6-1225dx Optical Drive Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Optical Drive Replacement: Schritt 8, Bild 1 von 1
    • Pull the optical drive out of the base of the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 162
