Zum Hauptinhalt wechseln
Cracked Grout Replacement
Was du brauchst
  1. Cracked Grout Replacement, Cracked Grout: Schritt 1, Bild 1 von 2 Cracked Grout Replacement, Cracked Grout: Schritt 1, Bild 2 von 2
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: Schritt 2, Bild 1 von 1
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: Schritt 3, Bild 1 von 2 Cracked Grout Replacement: Schritt 3, Bild 2 von 2
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: Schritt 4, Bild 1 von 2 Cracked Grout Replacement: Schritt 4, Bild 2 von 2
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: Schritt 5, Bild 1 von 1
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: Schritt 6, Bild 1 von 3 Cracked Grout Replacement: Schritt 6, Bild 2 von 3 Cracked Grout Replacement: Schritt 6, Bild 3 von 3
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: Schritt 7, Bild 1 von 3 Cracked Grout Replacement: Schritt 7, Bild 2 von 3 Cracked Grout Replacement: Schritt 7, Bild 3 von 3
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: Schritt 8, Bild 1 von 2 Cracked Grout Replacement: Schritt 8, Bild 2 von 2
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: Schritt 9, Bild 1 von 1
    • Your new grout is dry and ready for use.
Abschluss
To repair any other cracks in grout, repeat these steps.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 189
Insgesamt: 3,652
