Zum Hauptinhalt wechseln
Dell Inspiron 13-7353 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13-7353 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery up and out of the computer.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 985
