Zum Hauptinhalt wechseln
ASUS ROG Strix GL503VD-DB71 Battery Replacement
Was du brauchst
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 2, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 2, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 3, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 3, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 4, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 4, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 71
Insgesamt: 4,969
