Zum Hauptinhalt wechseln
OLPC XO-4 Touch Wireless Card Replacement
Was du brauchst
  1. OLPC XO-4 Touch Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Wireless Card Replacement: Schritt 2, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Wireless Card Replacement: Schritt 3, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: Schritt 4, Bild 1 von 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: Schritt 4, Bild 2 von 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: Schritt 4, Bild 3 von 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Wireless Card Replacement: Schritt 5, Bild 1 von 3 OLPC XO-4 Touch Wireless Card Replacement: Schritt 5, Bild 2 von 3 OLPC XO-4 Touch Wireless Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Wireless Card Replacement: Schritt 7, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Wireless Card Replacement, Screen: Schritt 8, Bild 1 von 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Wireless Card Replacement: Schritt 9, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 9, Bild 2 von 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Wireless Card Replacement: Schritt 10, Bild 1 von 3 OLPC XO-4 Touch Wireless Card Replacement: Schritt 10, Bild 2 von 3 OLPC XO-4 Touch Wireless Card Replacement: Schritt 10, Bild 3 von 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Wireless Card Replacement: Schritt 11, Bild 1 von 1
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Wireless Card Replacement, Back Cover: Schritt 12, Bild 1 von 1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Wireless Card Replacement: Schritt 13, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 13, Bild 2 von 2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: Schritt 14, Bild 1 von 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: Schritt 14, Bild 2 von 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: Schritt 14, Bild 3 von 3
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Wireless Card Replacement: Schritt 15, Bild 1 von 1
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
  16. OLPC XO-4 Touch Wireless Card Replacement: Schritt 16, Bild 1 von 2 OLPC XO-4 Touch Wireless Card Replacement: Schritt 16, Bild 2 von 2
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
Abschluss
Zach Yasuda
173 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-29, Amido Winter 2013 Mitglied von Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 405
