Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein iPad Pro 12.9" 4th Gen zu reparieren, verwende unsere Fehlerbehebungsseite.
    Fazit
    • The USB-C port is modular and can be independently replaced.
    • The lack of a physical home button eliminates a common failure point and may simplify repairs.
    • The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
    • The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
    • Gobs of adhesive hold most everything in place, making all repairs more difficult.
    Reparierbarkeits-Index
    3
    Reparierbarkeit 3 von 10
    (10 ist am einfachsten zu reparieren)
Taylor Dixon
67.119 Reputation
94 Anleitungen geschrieben
8 Kommentare
Who manufactures the LiDAR hardware?
Shaun O'Flaherty - Antwort
Looks like a ToF not real LiDAR. Apple marketing spin again
i.thanh -
https://tof-insights.com/time-of-flight-... Goes into details on pros and cons of a ToF versus LiDAR - and it appears there are many reasons why it makes sense to do a TOF LiDAR versus a full system when we are talking about a mobile device. Marketing spin, I hardly think so. It’s achieving the same functionality with many benefits on the device end.
Andrew C. A. -
When are you going to get a look at the IC’s in this?
Sean Davis - Antwort
it actually is a lidar and not a time of flight camera
cool tech with mick - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 37
Letzte 30 Tage: 190
Insgesamt: 52,302
