Zum Hauptinhalt wechseln
Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement
Was du brauchst
  1. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement, Disconnect the hose: Schritt 1, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement, Disconnect the hose: Schritt 1, Bild 2 von 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement, Remove the bottom cover: Schritt 2, Bild 1 von 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement: Schritt 3, Bild 1 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement: Schritt 3, Bild 2 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement: Schritt 3, Bild 3 von 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement, Disconnect the ground wire: Schritt 4, Bild 1 von 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
  5. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement, Remove the pump cover: Schritt 5, Bild 1 von 1
    • Use a 3 mm hex key to remove the four bolts securing the pump cover.
  6. Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement: Schritt 6, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Cover Replacement: Schritt 6, Bild 2 von 2
    • Remove the pump cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam O'Camb
196.767 Reputation
416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 308
