Zum Hauptinhalt wechseln
Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement
Was du brauchst
  1. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Disconnect the hose: Schritt 1, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Disconnect the hose: Schritt 1, Bild 2 von 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Remove the bottom cover: Schritt 2, Bild 1 von 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 3, Bild 1 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 3, Bild 2 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 3, Bild 3 von 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Disconnect the ground wire: Schritt 4, Bild 1 von 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
  5. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Remove the pump cover: Schritt 5, Bild 1 von 1
    • Use a 3 mm hex key to remove the four bolts securing the pump cover.
  6. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 6, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 6, Bild 2 von 2
    • Remove the pump cover.
  7. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Remove the pump hoses: Schritt 7, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Remove the pump hoses: Schritt 7, Bild 2 von 2
    • Use a flathead screwdriver to loosen the hose clamps at both ends of the pump.
  8. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 8, Bild 1 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 8, Bild 2 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 8, Bild 3 von 3
    • Pull the hoses at both ends of the pump straight off of their hose barbs to remove them.
  9. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement, Remove the pump: Schritt 9, Bild 1 von 1
    • Use your fingers to unscrew the hose barb from the outward-facing end of the pump.
  10. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 10, Bild 1 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 10, Bild 2 von 3 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 10, Bild 3 von 3
    • Bend the outer side of the pump compartment away from the pump very slightly.
    • Slide the pump out of the hole in the side of the pump compartment, then continue to slide the pump out of the compartment.
    • Do not completely remove the pump yet, as it is still tethered to the carpet cleaner by three wires.
  11. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 11, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the pump.
    • Remove the ground wire from the pump.
  12. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 12, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 12, Bild 2 von 2
    • Pull the two connectors straight off of the pump to disconnect them from the pump.
  13. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 13, Bild 1 von 1
    • Use your fingers to unscrew the remaining hose barb from the pump.
  14. Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 14, Bild 1 von 2 Karcher Carpet Cleaner BRC3015C 2018 Pump Replacement: Schritt 14, Bild 2 von 2
    • Your new pump may come with plugs on either end. Use an angled pick or small flathead screwdriver to pry these out before installation.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Adam O'Camb
196.940 Reputation
416 Anleitungen geschrieben
3 Kommentare
, Yes, why show how to replace it if you cant even buy it? top msg says:
( Karcher Pump, 110/120V 60Hz Flojet 86201110 Not for sale)
GERALD - Antwort
Ask Google for “Kärcher 8.620-111.0”
VauWeh -
The one we have has 4 mm screws. Otherwise, very helpful, thanks.
DAVID - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 1,420
